Sfb 3000.1
Neverenoughbass703
CarAudio.com Recruit
I had a sfb 3000.1d installed yesterday. The clipping light is coming on when I get the gain about a quarter of the way up. Is the amp bad. Or is my power supply not strong enough? I have a second battery installed. The battery is a hc2000 blu. Stock radio. Stock alt. Stock front battery. 2019 VW Jetta R Line
I had a mmats pro audio 3000.05 on it before. Never had a problem. But the mmats only rms 1700 at 1 ohm. So I got the sfb3000.1 because I read the xfl’s needed 3000 rms
What is the voltage at the input of the amp when the clipping light illuminates? Wouldn't be surprised if you're just maxing it out and only getting 1500w after rise and expecting more. Mmats makes some of the best amps out there and it may make similar power even though it's rated lower
Neverenoughbass703
Neverenoughbass703
Woodbridge VA
Boomin_tahoe
