why does everyone say a 50Hz tone... I just think if you set the gain w/ a 50hz tone... once that sub hits tuning at lets say 32hz... its going to be in danger because it plays so much harder than the 50hz tone that you set for your MAX output levelyou need --
- a DMM (digital multi-meter), or an accurate method of measuring AC voltage
- A 50hz 0db test tone on disk (can be downloaded at realmofexcursion.com)
- A few minutes to measure and make the adjustment
ya makes sensewhy does everyone say a 50Hz tone... I just think if you set the gain w/ a 50hz tone... once that sub hits tuning at lets say 32hz... its going to be in danger because it plays so much harder than the 50hz tone that you set for your MAX output level
or to say it another way... If I have a box tuned to 32hz, and I set the MAX output at a 50hz tone... think about whats going to happen when it drops to 32hz... make sence??
wat ?why does everyone say a 50Hz tone... I just think if you set the gain w/ a 50hz tone... once that sub hits tuning at lets say 32hz... its going to be in danger because it plays so much harder than the 50hz tone that you set for your MAX output level
