Setting gains with LOC
RI-Matt
What would be the the best way to set the amp gains when using a line out converter ?
Which should I set first, amp gain or LOC gain?
Should I let the amp do most of the work an just barely have the LOC gain turned up ?
I know using a LOC is less than desirable but I need to keep the factory head unit.
Thanks in advance,
Matt
timaishu Re: Setting gains with LOC
I didnt even touch the gain on my LOC when I used one. I exlusively used my amps gain knob.
Is that a Grand National in your avy? Is it yours?
timaishu,
Thanks for the reply.
Yes it's a Grand National ( 1987 )
Yes it's mine ( since '94 )
No you can't drive it //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif j/k
DBfan187 Re: Setting gains with LOC
LOC gains should be maxed out.
DBfan187
The LOC should be maxed out then go and set the gains on the amp ??
Matt
Godddddddddddddddddddddddddddddd!
I hate you so muuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuch! hahaha
I love those 87's. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I would play a 0db tone and see what the voltage is out of the LOC.
If it's something insanely high with the gain at 100% I'd back it off to something at the lower end (higher voltage) of your amp's sensitivity.
If it's 5v+ you may end up not having much range of volume control at the HU before reaching maximum volume -- even WITH your amp gains at thier min.
Thanks guys. I will try it out when I get a chance.
[hornedfrog1985 Re: Setting gains with LOC
We're going to need a picture with your name/date on it to prove that car is yours.
Today 08:29 AM
/QUOTE]
I put a couple pics of the car in my gallery, check them out. I have tons of pics of it, what in particular are you looking for ?
Matt
n2audio Re: Setting gains with LOC
How do I measure it out of the LOC ? It's just RCA hookups. Where do I put the probs ? I'm familiar with doing it for the speaker wires + - but I'm lost on the RCA thing.
Thanks,
Matt
RI-Matt
RI-Matt
Rhode Island
ST33M
Mike Mccabe
