With this chart I have set my left channel on my amp to 19.7 volts. When I set the needles in the right channel I get a different number which I can't remember. Also the volume from left to right is noticeably louder on the left side then the right side (right side is the one with the lower number)
I'm using a Crescendo 1000c4 and some powerbass 3ohm speakers in the front. As for the substage I have 3/4 bridged and can't get an accurate reading with the DMM on that.
When I put the needles in the 3/4 bridged terminals, the voltage numbers are weird. If I have the gain all the way down it's around 5 or .5 volts, I can't remember. If I set the gain up half way the voltage comes up to 37.9v or so. Once I start to turn it up it barely gains any voltage and 3/4 of the way it stays at 38.2 and if I turn the gain on MAX it stays the same as 3/4th of the gain.
The chart asks for 44.72v for 500rms (the amp is supposed to do that bridged at 4ohm) and I can't even get anywhere near that number let alone over 40v. I have the headunit at +15 for the sub and all the graphic settings at 0 and sub system at 2. I set it to 1 and made no difference on the dmm.
//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
