Setting gains on amp
CELLERBR
Hey fellas i have a small problem...how do i set the gians on my amp for my 5v hu if my amp is only rating for 4v? Keeping good power yet not clipping? Am i missing something? Rockford says to turn the gain all the way down but if i do that the sub doesnt kick in till the volume is WAY up there?.....any info is very much appreciated!
-Ian
I have a PG MS2125 amp rated at only 2V input. My HU puts out 4V. I e-mailed PG and they told me to set the gains "as normal" basically just ignoring the 2V limit. I am now wondering if this is adding distortion/clipping to my syetem as well when I exceed 2V input.
Well, you should know that
1) If you have a Panasonic head unit, your pre-out voltage is not 5 volts (If you have Eclipse, it is)
2) Odds are that you probably will not run close to your pre-out ratings
3) Use some sine waves and test pre-out voltage using an AC voltmeter or DMM or just turn the gain up until you hear distortion, then back it off a bit //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Hi there,
I am using a Alpine 9815 with 4V preout and a Blaupunkt Velocity VR6000 with gain setting from .25mv to 8v. Can you advise on how should I use a DMM to do gain setting?
I don't own a scope though
Thanks for advising
Turn the gain all the way down and turn you volume up to 3/4. Then turn your gain up until you hear distortion and then back it off a little. That is the easy way to do it.. not the proper way, but the easiest.
Sorry to bring this thread back, but I have an additional question: What do I set the bass boost and crossover to for this gain distortion check? That's going to greatly affect the output sound.
CELLERBR
CELLERBR
KY
Darwin
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
