I've been getting clipping lately, which I believe is attributed to my amp getting hotter since I've recently put back in my rear seat. Changed nothing electrically, just put the seat in. I figure it might also be related to the gain settings since when I set them I used my ear (not always the best method) so I thought I would take the 20 minutes and do them right tonight...wound up running into a brick wall:
I'm using an alpine mrp-f240 4-channel amp, bridged to @ 100w rms x 2 @ 4 ohms.
http://www.crutchfield.com/S-3UitsnSCpg7/cgi-bin/prodview.asp?I=500mrpf240&search=mrpf240
By the method used here, I should be getting a gain voltage for each set of channels (1 & 2, 3 & 4) of 20v each set ---> Sqrt(100*4)=20. However, when I use my DMM on AC settings, the MAX gain goes to only 5v for the channel 1&2 setting. I didn't bother with 3 & 4 after having this issue, btw. I unplugged all other RCA's except for the ones I was actually using, once again 1 & 2. Am I missing something here? I have all 4 RCA's running since it seems to make sense because I'm using each channels' input, whether it be power or ground.
Recap: should be using a gain voltage of 20v, but maximum gain per side is only 5v. What am I missing here?
Edit: volume was set on 24/33.
