Phoenix Gold 400.1...Confused.
Frankensuby
I'm in Ur F0rumZ
929
PA
I'm looking at the specs on the Phoenix Gold Xenon 400.1 Mono amp, and it says stable load at 4, 2, and 1 ohm load. I understand that with my soon to be installed PG X10d2, my wiring will drop it to a 1 ohm subwoofer, and that the amp is designed to handle this.
But does the amp increase in output? Or because it was designed to be able to handle the 1 ohm, will it stay around 400 rms? I'd believe the amp would increase in output, but I'd like to know for sure.
~Levi
It's still all good. I was looking at Birth sheets and I've seen this putting out nearly 600 RMS at 4 ohms on 1 sheet, so it'll fit my application perfectly //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
~Levi
~Levi
Do not wire the xenon @ 1 ohm. You wont gain anyting, but current draw. Its pointless.
I'm not good with the wiring. Only tutorial or diagrams I see on sub wiring shows how to make the sub go down in ohm. How would one go about wiring a DVC 2 0hm sub up to 4 ohm?
~Levi
in series
The xenons make the same power at all ohm loads!!!! Wire it at 4 ohms, and be done with it.
Thread/
I know it says that, but the PG site SPECIFICALLY says that their Mono blocks make MOST at 2 ohms. I will wire it to 4 ohms most likely, unless there is a way to make it 2 ohms.
The difference could be negligible, but it still states from PG, that it is best at 2 ohms. I was just trying to let everyone know //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
~Levi
~Levi
You're not getting this.
1) You cannot wire your dual voice coil sub to 2 ohms on that amp without using just one coil and I highly recommend NOT doing this.
2) The xenon line of amps will do about the same power from 1-4 ohms. What they have one the site is talking about their other lines and it is "technically" correct with xenon line as well.
Your logic is incorrect with their statement:
"*Phoenix Gold Mono Block amps make full power at 2 ohm"
This is what you think it says:
"*Phoenix Gold Mono Block amps put out the most power at 2 ohm"
That is faulty logic. The max power the xenon 400.1 does is a rated 400rms. At 2 ohms, the amp does full power. At 1 ohm, this amp also does it's rated power. At 4 ohms, this amp also does it's rated power.
Do you understand now that your logic is incorrect? Everybody else seems to understand this, why can't you?
Frankensuby
I'm in Ur F0rumZ
Frankensuby
PA
Immacomputer
