Setting gains.. Little help..
You talkin about setting gains for your subs? What kind of HU do you have?
The bass level usually doesn't affect the subs, just the front and rears. Your sub-out setting affects the pre-out level to the sub(s). Set your gains with the sub-out turned up, EQ set flat, bass=0, loud off and volume around 75% of your HU's max volume (maybe higher depending on HU). Then set your gains on the amp, hopefully with a DMM.
shinychromes
shinychromes
nyc
helotaxi
