I got my Pro60's in yesterday, and they were a huge improvement over my SL60s. I need to break them in, so I didnt turn them too loud. Which is a good thing since I lost a little bit of hearing seeing how loud my SL60's would go on 150w (the answer is too loud)
My only complaints are I cant quite turn the tweeters down enough (so I need to use headunit to turn down the treble, which also turns down the woofers slightly, leaving it sounding very soft. I dont mind the aluminum tweeter so far though. I think it actually makes things sound a bit more realistic since most high frequencies are metal objects to begin with, whats a better way to replicate them than with a metal speaker?
Also, a quick question about the JL amps. It automatically switches the voltage down right? Because with my SL60's I set 150w (with a 1khz test tone) to be at 30/35 on the HU. Since the Pro60's are a lower impedance, at the same voltage it would be producing higher wattage (correct?). But because of JL's regulator, no matter what impedance speakers I use it should be producing the same wattage at the same volume level no matter what speaker impedance is used? hope this makes sense.
