setting gains for head unit (nec)
jdmferio13
feayfm
is it necessary im only running a 2 volt preout hu.We got the volume to raise from 25 max to 30 max but had to fade the speakers to the rear -4.and then did the amp and hooked up everything and it got quiter for some reason.Is it necessary to do that with the head unit or no and why do i have to fade to the rear speakers and not be able to hear the front mids
thanks for answering cause it obvious what i meant can i just set the gains on the amp with the o-scope and just go by ear with the headunit.I really need to get a 4 volt or higher preout hu
okay sorry hard to explain.basically do you guys set your headunits by ear or with o-scopes.we did mine its only 2volt preouts.but when we did it clipped so i had to fade the front mids and its not loud anymore if that helps sorry max volume is 30 btw.
i also have stock interior speakers with a shitty sony headunit wondering if i upgrade the headunit is it gonna make a huge difference with the pre out voltage
jdmferio13
feayfm
jdmferio13
Central,PA
1hawaii50
vegang
vegang
