serpentine belt tensioner
Theres no way stock isnt strong enough.
It took all I had and a breaker bar to get my stock one too move.
Youre thinkning off of the real problem I bet.
What did the Jeep dealer say?
get a smaller belt or a larger idle pulley. you can even find some washers or shims to jack one accessory away from the block if you have to. I had to do that when every combo of smaller belt was to small or a bigger idle pulley was to big. A few washers from the leftover hardware bucket was all I ended up using
i have a 2 foot wrench, pull that sucker back with ease. I can do it with one hand and hold it there while i put my belt on.
Once the belts on, i let go of the tensioner and dose not go down very much after the belts on.
i found a belt 1/2 inch smaller and for the life of me, i could not get it on //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif ill have to fine 1/4 smaller.... should work. but the tensioner is weak i think
there still look at the car from the window problem not working remember? also told them to look at the tensioner.... its over 4 hours into them looking at it. this is not good.....
i have a 2 foot wrench, pull that sucker back with ease. I can do it with one hand and hold it there while i put my belt on. Once the belts on, i let go of the tensioner and dose not go down very much after the belts on.
Ok...how can you say this and than :
This.
If you have a bunch of slack , How can you not get 1/2 shorter belt on?
Bring it too a mechanic if ya cant....i can almost promise you its not the tensioner....Unless you are putting it on wrong.
Ahhh...keep us updated.
So what alt do you have on it when you brought it in....the mechman adj. reg one?
MasterOfAllBass
Team Minnesota's Loudest
MasterOfAllBass
Minnesota
MasterOfAllBass
michigan born
    May 14, 2026
michigan born
    May 14, 2026
