Series vs. Parallel
Series and parallel don't change the sound quality or anything like that. It just changes the resistance, which will alter how much power goes to your subs. Using your dual 2 ohm sub, parallel would give you a resistance of 1 ohm and series would give 4 ohms. 1 ohm will get more power from the amp, but is your amp stable at this resistance?. If it's not (and you said 4 ohms most efficient), then go with series and a 4 ohm load.
Just to be warned, there will be some who say resistance does affect SQ. This is only the case on paper. Never, will the average consumer notice any differnce in SQ when changing the resistance of the system though.
turnstylez18
turnstylez18
Toronto
AVSTANG02
vegang
vegang
