Semi-decent 10" sub for a (mostly) stock system?
Hi,
I have 2012 Jetta GLI with the stock HU and speakers. Last week, I swapped the fronts for a 6.5" Focal IS165VW (integration) component set that is still being powered by the OEM unit. I know it's not ideal but the SQ actually improved a lot.
Now I need to get some bass presence to go with these nice sounding Focals . I listen to a lot of jazz, fusion and rock mostly. So I am looking at a semi-decent SQL-oriented 10" sub to install on a custom fiberglass (sealed) box of around 1-1.5 cu.ft. that will kick nice and TIGHT on those bass drums but not "boom" around like crazy or make my trunk rattle (much).
I already ordered a Rockford Fosgate PBR500X1 mono amp (looking to tap the fronts or rears) so I am leaning towards a 4-ohm DVC sub, or if possible, even a 2-ohm DVC to make the most out of this little RF amp. I am limited to a sub that can be easily bough on eBay or Amazon since I'll need to have it shipped to Mexico, so no custom or boutique subs please.
Any 10" SQL-oriented (2 or 4ohm DVC) MAINSTREAM sub recommendations for a 1 cu-ft custom fiberglass sealed box?
Thanks for your advice!
Kimo
Hi,
I have 2012 Jetta GLI with the stock HU and speakers. Last week, I swapped the fronts for a 6.5" Focal IS165VW (integration) set still being powered by the OEM unit.
Now I need SOME bass presence to go with the nicer sounding Focal components. I listen to a lot of jazz, fusion and rock mostly. So I am looking at a semi-decent SQL-ooriented 10" sub to install on a custom fiberglass (sealed) box of around 1-1.5 cu.ft. that will kick TIGHT and nicely on the bass drums but not "boom" like crazy or make my trunk rattle (much).
I already ordered a Rockford Fosgate PBR500X1 mono amp (looking to tap the fonts or rears) so I am leaning towards a 4-ohm DVC sub, or if possible, even a 2-ohm DVC to make the most out of this little RF amp. I am limited to a sub that can be easily bough on eBy or Amazon since I may need to have it shipped to Mexico, so no custom or boutique subs please.
Thanks for you advice!
Kimo
A Focal sub would be a nice addition
Kimoterapias
Kimoterapias
Mexico City
els1989
