Second Battery
That's nothing like the spark you'll get if you touch positive to negative. That's what we're talking about. That's like a static spark in comparison //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
But that had already been covered. So I just thought I would throw out a random .02 //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
i'll just use 250a fuses on all of them, they're all the same price from where I get them
for instance.. in my system
my amp draw's 240 a
i have a 300a fuse on my alt + to my batt+
then a 300a fuse on my under hood batt run too my sec batt. then 300a fuse before the batt
then a 250a fuse from batt+ to amp +
Go disconnect your negative terminal in the dark. Than hook it back up. It will spark.
Meh.....A few electrons will arc over when they're close. Nothing to worry about, though. Definately not like a + to - short on a big battery.
See my next post. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I would do 300a on the + wire, but the store only has 100-250a fuses, I can always change them later on though
250 is more than adequate.
alright, so now 2 250a fuses on the + run to back batt, then 200a fuse from back batt to amp, sounds good.
also, knukonceptz just shipped out my wire today :eek:
weird thing is, 50ft of 1/0 is only 11 pounds?
Sounds like a kick *** plan:cool:
If you don't mind me asking, how much did a spool of knu cost you? PM me if need be.
jbizzle
jbizzle
Chicago, IL
jbizzle
