second battery
turnign caps lock off might help you get 14v solid. adding a second battery will make the voltage come up because you add more reserve capacity. but that wont stand long if your alt is too small. I'd look into a bigger alternator and do the big 3 then if you still dotn maintain the 14v you want then add a second battery. adding a better battery up fornt will help out too. stock battery prolyl isnt designed for that kinda draw on it. but even with my setup 14v is hard to maintain with jsut one of the amps on a stock alt. if your alternator can't keep up with your current draw the voltage will drop and continue to do so as the battery drops.
yea, also most alts even HO alts regulate the volts out put. my iraggi only does 14.3 on a good day. get an external voltage regulator with your HO alt. one yellow top or bigger as your main battery with the big 3 should take care of it. also HAVE GOOD GROUNDS.
blue-accord
blue-accord
ATlanta, GA
photocrazy8
