second battery
Unless you ran it parallel for 24 volts, or is it series, i get those confused a lot. Then you could drop it through a genius scheme of changing to ac,using step down transformer,and changing back to dc...for 14 volts. However, you'd still need to upgrade electrical wiring as well.
The purpose of the second battery could be for many reasons, but mostly to help out your main battery from overstraining itself and it makes a good distro block for a lot of wires.
well take a look at my sig i upgrade to the 2/0 wires a bigger alt and the big three and i know i still dont get a constant 14 but i havent put a meter to it yet but im sure cause i still get alight dimming at .5 ohm but that should be normal for that application
So overall you're looking at around a 1k watts? If 360watts pulls 33.6 or whatever amps, then 1000 would be somewhere like at least 95 or so, so what kind of stock alternator do you have?
MAN, I WON'T BE ANYWHERE NEAR .5 OHMS.
HAVE NO IDEA ABOUT THAT STOCK ALT, GUESS I SHOULD LOOK IT UP.
blue-accord
blue-accord
ATlanta, GA
photocrazy8
