Second battery help??
DJSlowfets
5
CA
It seems If I want 1100 watts out of my amplifier I will have to add a second battery.. ive always been told match it with your one up front as close as you can so it doesnt draw. My stock battery is new 2 weeks old and is 635 cca and I have a 110 amp alternator. So I have two batteries bookmarked dont go off brand or what you have heard just go off what my system needs to push a Belva BB300D amp at 1100 wattts at 1 ohm. It may be neither of those just figured id start there.
http://www.amazon.com/Kinetik-HC800-BLU-Watt-Power-Cell/dp/B000LUDEOI
http://www.amazon.com/Shuriken-SK-BT20-Compact-Power-Battery/dp/B00NF0R5XC/ref=sr_1_4?ie=UTF8&qid=1428007690&sr=8-4&keywords=agm+audio+battery
That amp makes rated, or what it's going to do at 14.4v. Batteries don't get you 14.4v.
Batteries do very little until the voltage drops to 12.6v.
If you set that amp right with a clean signal you should not need anything.
That amp makes rated, or what it's going to do at 14.4v. Batteries don't get you 14.4v.Batteries do very little until the voltage drops to 12.6v.
I plan to.... Im gonna get a 320kbps 60 hz sine and set it with my headunit at 45 right where speakers start to clip then take amp gain up to 32.40 volts that HOPEFULLY will make about 1100 watts clean.
If voltage is dropping bad lower the gain some. A few watts won't be noticeable.
DJSlowfets
DJSlowfets
CA
LosIsATool
michigan born
    May 14, 2026
michigan born
    May 14, 2026
