Second amp electrical noise
  • 2
abs777
KY
In my boat I had the factory clarion amp powering 4 speakers and the sub. They ran the bow speakers (2) off of the head unit. I decided to by another amp to power the bow speakers. I installed it and it sounds good, but when I turn on the blower I get the electrical noise through those speakers. It's a loud whine like an electric motor. I thought it was a ground loop so I ran dedicated wires (power and ground) to the second amp and the same thing. I found it it's coming from the input. If I plug my iphone into the amp it sounds great no interference. I have done the following...and it makes no difference and still has the noise...I am at a loss.
1. I originally had the input to the second amp being the speaker wires from the head unit - noise
2. I thought it could be those speaker wires so I unplugged the RCAs going into the clarion and plugged them into the Pyle (second amp) - noise
3. I ran the 6th channel from the clarion amp into the high input to the second amp thinking it would clean the signal - noise
How can I eliminate this noise from the pyle...why doesn't the clarion have it?
Thanks guys...this is so frustrating.
I was afraid that might be the case. I don't know why it's clear when I play the iphone through it, but the headunit is causing such noise.
I have a 2018 f150, looking to keep factory head unit, not running a dsp as this is budget build. I have a t harness, skar doors, amp and subs...
So, why the fukk is the pedo replying to me? He started the shitt again and I am responding. What don't you understand?
75
8K
92
abs777
abs777
KY
abs777
    May 16, 2024
    May 16, 2024
