inferno1985 10+ year member Senior VIP Member 313 0 216 Jun 10, 2015 #1 Is there a way to wire down single voice coil subs that are 4 ohm to a 2 ohm load at the amp? Click to read more...
OP inferno1985 10+ year member Senior VIP Member 313 0 216 Jun 10, 2015 Thread Starter #3 So 2 single 4 ohm subs will see 4 ohms at the amp? Regardless of the wiring?
LosIsATool 5,000+ posts CarAudio.com Veteran 18,504 73 Pensacola, Florida Jun 10, 2015 #4 So 2 single 4 ohm subs will see 4 ohms at the amp? Regardless of the wiring? Click to expand... 2 svc 4s wired down will be 2ohm. 1 svc 4 will be 4ohm
C1500martin 10+ year member CarAudio.com Veteran 3,399 1 Cali Jun 10, 2015 #5 http://www.the12volt.com/caraudio/woofer_configurationsm.asp
