Searching for inexspensive setup
you could do something like:
Dcon or DC lvl2 12 inch for $150ish
refurbished kicker zx300.1 amp $100-120
pre-fab sealed box for $40ish (or build a box If u can)
buy used and save
Amp: Audiopipe APSM-1300 2000W Mono Mini Amplifier : APSM1300 : $108.95 : VMInnovations.com
Sub: SA-8 D2 - Sundown Audio 8" Dual 2-Ohm SA Series Subwoofer | WoofersEtc
Box: sealed prefab. Make sure you seal it up some more.
Wiring: Audio Savings | Cadence WK41 4 Gauge Complete Car Amplifier Installation Kit Amp Wire Kit
You can swap out the sub for something else (bigger) but either get 2 d4's, 2 d1's, or 1 d2 sub to match that amp. You can get a new 15" Orion Xtr pro d2 for under $150. 12 and 10 inch even less. Also you could get 2 of the regular xtr 10's for $140.
He said he wanted a loud sub. A 12" CVR sealed is far from loud...
depends what loud is to him.... to me loud is 142+...for him it may be a 120 or 130...... its all in prefrence. but OP i have 2 12 inch bxi's if you want to take a look at them. 3'' dvc and 20lb motor... hmu if you're interested
OP, get an APSM-1300 (1000w @ 1 ohm), audiopipe TXXBF12 (triple stacked motor, 4" coil), go to lowes or HD and get a sheet of MDF for $30 and build up a box using a design from one of the members on here.
  • Locked
If you’re going to spend that kind of money, you should be looking at Beryllium domes too. Like the ScanSpeak Illuminator D3004/6040-00 Beryllium...
This would go a long way to alleviating the dimming issue, up to around 4000 watts. It can handle 100A continuous and up to 285A 7 second burst...
573
I had some 9500 series 12s by MTX that were some slamming subs!! Should have kept those along with those torpedo RE XXX 12s
15
973
Ockanator
Ockanator
Columbia, SC
Audio4ever
    May 16, 2024
    May 16, 2024
