Searching for inexspensive setup
you could do something like:
Dcon or DC lvl2 12 inch for $150ish
refurbished kicker zx300.1 amp $100-120
pre-fab sealed box for $40ish (or build a box If u can)
buy used and save
Amp: Audiopipe APSM-1300 2000W Mono Mini Amplifier : APSM1300 : $108.95 : VMInnovations.com
Sub: SA-8 D2 - Sundown Audio 8" Dual 2-Ohm SA Series Subwoofer | WoofersEtc
Box: sealed prefab. Make sure you seal it up some more.
Wiring: Audio Savings | Cadence WK41 4 Gauge Complete Car Amplifier Installation Kit Amp Wire Kit
You can swap out the sub for something else (bigger) but either get 2 d4's, 2 d1's, or 1 d2 sub to match that amp. You can get a new 15" Orion Xtr pro d2 for under $150. 12 and 10 inch even less. Also you could get 2 of the regular xtr 10's for $140.
He said he wanted a loud sub. A 12" CVR sealed is far from loud...
depends what loud is to him.... to me loud is 142+...for him it may be a 120 or 130...... its all in prefrence. but OP i have 2 12 inch bxi's if you want to take a look at them. 3'' dvc and 20lb motor... hmu if you're interested
OP, get an APSM-1300 (1000w @ 1 ohm), audiopipe TXXBF12 (triple stacked motor, 4" coil), go to lowes or HD and get a sheet of MDF for $30 and build up a box using a design from one of the members on here.
Ockanator
Ockanator
Columbia, SC
Audio4ever
