Sealing Q's...
bcarpenterfhl
Kiss Me I'm Shitfaced
When you make a slotted box, there's some spots on it that are difficult to seal. For instance when you put the top of your box on, how do you seal behind the port extension and inside the port itself? When i encounter this problem, i just simply seal it on the outside. Is this right?
sorry, captions are hard to read. The first one says "Like Here In The Corner " and the second reads "This is what i was talking about when i said sealed from the outside. The black stuff is the caulk. Is this what you're supposed to do when you cant seal from the inside?
i usually stick my head in the hole w/ a flashlight in the box and seal it up //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif youve got 3 holes, should be simple to do.
in those kinds of tight spots i just get some glue on my finger and the use my finger to make a nice bead across the joint, but if you glue is set up well and its not too thin i would think its ok.
I use my finger all the time //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Just blob it on there and slap it on, when i run out, just blow some more on //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
bcarpenterfhl
bcarpenterfhl
San Francisco/Hillsborough, CA
supa_c
chillin
    Jun 14, 2024
