Sealed Glass Sub In The Dash????
where the hell do you put your feet?
yeah were the hell do you put your feet? i've seen that 12" midbass pro audio driver in that s-10 too,but it wasnt in the kicks lol. shoot why not just get rid of the brakes,clutch,and gas pedals and install a handicaped drivers system in the dash and steering wheel? that way you can put all the daamn speakers you wan in the floor board
when you remove the entire interior of a car and look on how the inner structure and outer shell come together often depending on the car there are large open pockets between the two layers of metal. you gotta bust out the torch to put the hole in it then build a baffle out from it. my 87 firebird had 8's there and i probably could have gone up to a 12 but i know a 10 would have fit. its all on what you use and how you use it. before anyone goes hacking into those corners be sure you arent going to hamper the cars structure if you cut into there and dont cut out any more than whats needed. after kirk cut the hole out they sealed the sections off by welding more steel in place and probably a reinforcing brace or 2. this is the corners where the firewall and kickpanel meet.
screw that-too much freaken work!!! hell you mind as well put the car on a lift cut out holes in the kicks,and build a box under the car to accomidate the sub or midbass driver in the kicks
Doesn't Squeak have 10" "mids" mounted in his doors?
Not yet......by the end of summer I will though //content.invisioncic.com/y282845/emoticons/up2something.gif.dd110ecf3ae4b76050d87598f2f8de7c.gif
Also, here is the article of Earl Z's car, which had 15" subs in each kick:
To make it even more amazing; those were prototype B & W home audio subs. Retail price; $15,000 for the pair //content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif
owned //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
i need to make a gif avitar //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
Yeah Ive seen pics of that S10 with 12's in the doors. Whole new door panels outta 'glass.
How about a 10"er on the A pillar or something....If its not driven, might kinda get in the way of ohhhh, seeing:D
Or if you got a wide B pillar. Right by the ears.
i got a issue of street trucks magazine and it has a dodge dakota in it and it has 2 jl 10" subs in a custom sheet metal dash with the subs facing straight up outta the dash and in the middle a lil door pops up with the HU in it it looks pretty bad@ss
what people do to their cars is crazy as hell !!! i would consider running 10"s in the doors. im sure they have to be pro audio midbass drivers for sure
Nope //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif Home Audio has some 10" midbass drivers, and some 10" subs will work well as midbass (such as in my case //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif )
Having subs up front does make a difference. I had an Iasca competitor listen to my vehicle a couple weeks ago and he was very impressed with the bass up front. It's just does it make enough difference to justify molesting your vehicle so much? Most people probably wouldn't think so. But it does make your car famous as I've found that most people who come by Adire from the forums recognize my car. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Steven Kephart
Adire Audio
HERETIC
HERETIC
miami
freshbondoscent
Doxquzme
    Jun 20, 2026
Doxquzme
    Jun 20, 2026
