Sealed box for e12kd2
  • 2
amm986
The sealed box will be in the back of a 1998 Accord, so I should have plenty of space.
The dimensions of the box are W=17.25" H=14" D=11", with 1.08 cubic feet before displacement. Since this will be my first box any helpful hints or techniques would be greatly appreciated. Thanks for your help in advance. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Andrew
make sure it is air tight....before screwing everything together use some silicon sealent on the gaps.....do the same after it is assembled.....use 3/4 mdf or larger .....tnuts work good for connecting the sub to the box....peace
I dont think this forum is letting that link work. It keeps changing it to a link to this forum. Try this. Just change the dot...
10
No problem. The Dayton ultimax is one of the better sounding sealed subs I’ve heard. I kinda want to try the 18 in my ride.
If you experience any air leakage from the screw holes.. adding Clear or the color of you choice of Silicone works just fine after a 24 hour cure...
10
Stereo Integrity hst12, only needs .6cuft after displacement. I have mine in a 15 inch double wall birch ply cube, .55cuft after displacement...
Most ported boxes will be 1.75-2.5cubic feet of airspace. That's just a base requirement. Sealed will be .8-1.25. That said ported has the...
amm986
amm986
Shepherdstown, WV
amm986
    May 23, 2024
    May 22, 2024
