SAZ-3000d's strapped at 1 ohm
6000 watts RMS im guessing. if you have the correct electrical. you have these in your sig, why don't you just clamp em and see for yourself.
Well they're rated at 3000wrms at one ohm, but are underrated I hear. But what would they put out at 1 ohm strapped, or .5 per amp.
And as for the electrical. I was thinking 2 positive and 2 negative runs of 1/0 from front to back, and probably 4 deka 9a31's in the back, and a G31 Yellow Top up front with a 290 amp DC alt.
Prolly 18k plus at least. Plus, why strap them at 1 ohm when you could strap them at .25?
Strapping at .25 ftw.
i strapped mine at .5 .... they were power hungry at .5 strapped but it was fun! got a lil warm at times.
Lol that's way too low for what I want. I don't want a load lower than .5 on each individual amp since it'll be played lightly for daily, and hard for demos.
let me tell u.... dont do it... run them at 1 ohm per amp... they will do it... but ur ****** the life out of them... if you have really good electrical they will stay relativily cool but the amp will pull more current than needed
the output at .5 with a little moar power as alot more current draw isnt worth just running them at 1 ohm each with a much lower current draw and GREAT amoutn of power
I've heard they'll do .5 just fine.
They will run 1 ohm strapped daily, but I don't recommend that for everyone. I'm sure Jacob won't recommend it either.
Why wouldn't you recommend it for everyone. Is there any advice you could give about doing it safely. I'm in a bit of a tough spot.//content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
they will run at .5 daily fine but they will get hot and pull large amounts of current that isnt necessary....
As long as I don't do damage to them I'll be happy.
I have four 2 ohm dvc subs. I was planning on grabbing two more amps, but the funds aren't quite there.//content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
rmzsuzuki89
rmzsuzuki89
St. Pete, FL
SWFL
Mike Mccabe
