same wiring harness?
  • 2
wErd
Maker of All Good Threads
5,712
usa
does anyone know if the pioneer deh p6600 has the same exact wiring harness as the Pioneer Premier DEH-P660? id like to get the premier cause my pioneer is messed up, but i dont want to take out the entire wiring harness and have to wire it all up when i can just unplug the harness from the headunit and plug the new headunit up.
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
584
To add the tv, I got a second deep cycle battery, ran thick cable from my starter battery to the deep cycle battery(or you can run to a dc to dc...
I don't think it's that easy to answer "for a complete beginner". amp and speakers ratings are those peak or RMS? Are these already installed...
No different than powering multiple amps. I'd use a fused distribution block. Power each amp. Probably easiest to just add that to the existing...
DJ subs are designed for efficiency, car audio subs are designed for low end in a small space. So above ~50hz the DJ sub will kill a car audio...
wErd
wErd
usa
Redford
    May 18, 2024
    May 16, 2024
