sail panel buil log
Honez
SMOKING CAUSES CANCER
so i got a pair of TBI HDSS TWEP51 tweeters about a week ago. temp installed them in order to get the imaging correct via the angle mounting cups for my sound stage. req and i just spent the past 2 hours final mounting them, wrapping them then finally coating them with some epoxy resin. here are the build pics. we have to finish the pods, they are currently drying after their first coat of resin.
the first picture is of the temporary amp\xover installation in the boot. eventually there will be a complete false floor install after we get back from deployment.
let me know what you think.
this is the tweeters installed using the angular mounting brackets, the tweeters are pressure fitted in, and they are VERY tight. the soundstage is very high, we spent an hour or so playing with the IASCA disc and the angle. it came out superb.
this is our workbench. aka reqs false floor cover and our tools and dinner (chipotle burritos)
we started by taking the bob smith industries IC2000 cyanoacrylate glue and permanently fixing the angle we fixed.
we proceeded to add supports to the front\back of the cup so that when we stretch our form the cup has a stiffer support behind it. we just used 1\4" wooden sticks from the hobby shop. you could use chopsticks or Popsicle sticks.
then we put glue around the edge of the mounting cup to start our form so that the harsh angle would not interfere with the fabric and keep the area where the tweeter is mounted stuck where we needed it.
layed the fabric down and shot it with some PT-15 Zip Kicker accelerator.
we proceeded to glue around the edge of our working area and spraying accelerator as we went around. then trimming it after we were satisfied with the tightness of the stretch and all the wrinkles were out. a second set of hands works very well here.
a test fit in the car before we glass them, and it all looks great! dont mind the wrinkle in the center of the cup - that will be cut out when we are finished.
take them upstairs to the patio and get a nice thick coat of resin on there.
and thats where we stand. after they are done we will give them a nice light sand, and since this is not a supportive structure, we are going to fill the cavity behind the tweeter with expandable foam to help with the rigidity, and cover with some sort of fabric.
keep posted, there is lots more to do.
honez \ req
it was really cold outside so the resin was not too happy, we had to take it inside, hopefully it starts drying under the lamp we put over it. //content.invisioncic.com/y282845/emoticons/uhoh.gif.c07307dd22ee7e63e22fc8e9c614d1fd.gif
Hey man cool look and clean work, something I do in order to mount rings is use cardboard and roll it around the speaker and make a profile that way, then when you are done you can make an exact copy so that the pods are both exactly the same,
here are some pics...
Good job bro, I can't wait until my IASCA disc comes in! So I can learn how crappy my Image really is //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Good to see some SQ efforts.
I assume those are crossfired to opposite listener, or thereabouts?
THATS ABSOLUTELY GENIUS... THATS MOST DEF SOMETHING ILL HAVE TO REMEMBER WHEN WE BUILD MY PODS FOR MY ID CX 62'S
ok so i just got a second coat of epoxy resin on my sails... hopefully they will be hard and thick enough to sand down a little then fill them with expanding foam. then do a light finishing coat of body filler to fix any surface imperfections. then primer them with flat black paint. then wrap them with some grill cloth that matches the cloth on my door panels.
should be complete by Sunday if all goes well
will post more pictures once we start up again
honez/ req
Hi guys, I am stumped, I own VW transporter T6 SWB van, upgrading at the moment popping in HD600/4, HD750/1,JL W7AE, JL C5 625 3 way in the front...
I haven’t received my order yet but was wondering if I still need a baffle to go with installing 6.5 speakers in my door panels. What are some...
You're probably right. I have two Taramps smart 3 amps and four 10 inch CT sounds tropo for bass. I'm actually going to only install one of the...
14
Honez
Honez
Virginia Beach, VA
tez4life
slater
    May 2, 2024
slater
    May 2, 2024
