sa12 break in?
I am not really sure what I mean by that. I was looking for a good amount of bass and I have heard the eights hit really good and thought it might look cool to have two little eights pushing out good bass but the 12 would also look good. What woul hit harder. I have about 2 1/2 cf of space
DD uses lighter spiders to make the claim their subs dont needa break in or they are pre broke in . i was refering to a sub with super stiff suspension . try pressing in a dc lvl 5 by hand and tell me it doesnt need some time for the spiders to losen
DD has some pretty stiff setups actually. AQ/DD and many others all claim they require break in prior to use. However, it has nothing to do with thermal issues what so ever. It is actually used to help over ride what would otherwise be a warrantied repair.
There is a thread where holic and I discuss this topic at great lengths where I was referring to some of my tests over a few prototype drivers (for an unnamed company) and while I didn't believe in break in it appeared to work with those drivers. However, after that discussion and going back over data I actually found that I was wrong and had to rewrite the company explaining my error and exposing what was the weak point of the drivers.
There is nothing wrong what so ever with taking it easy on a driver fresh out of the box, but to be honest it is not required on any driver. However, after the suspension is wore down a bit the T/S specs will change as will the characteristics of the driver. Which can of course cause damage if the driver has soft parts that become to weak over a given period of time.
Well I have 2 kicker comps 12 right now on 3 to 400 watts sealed and its ok but want more will 1 Sa 12 or the 2 8 s do it for me or should I save up get new 2000 watt amp and get 2 12 I'm new to this I used stuff I already had for now but when I do my new system it will be custom box so don't want to have to redo it
Anyone who thinks a sub needs a "break-in" time is just getting taken for a ride by the manufacturer. When people hear "break-in period" they think you need to play it at less than recommended power at a certain freq. or whatever. Its all bs:fyi:
Of course a sub sounds better after the suspension loosens up, doesnt mean you only can throw 600 watts to a 1200 watt sub until its loosened up. Its really a play on words using "broke-in" because yes you can say a sub has been "broke-in" after you play it for so long and feel its loosened up, but no reason to go low power. Let that baby play.
Xjeff
Xjeff
The dalles
-01limited-
NorthFramingham
    Jun 30, 2026
