SA-8 vs. 1508???
//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif vids of the minitruck in ur sig?
Haven't made any yet. Me and Tommy are doing very similar full tilt scores, but he does more impressive scores with little cone area than I do. My truck is an ext cab, so I run a little more cone area than he is able to //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
jacob if you reading this:
later if ill need a recone, could i buy a new basket with the bolts and the spacer ring/plate that will hold down the spider?
jacob if you reading this:later if ill need a recone, could i buy a new basket with the bolts and the spacer ring/plate that will hold down the spider?
I haven't brought in the bolt down rings for stock yet. I will have all the other parts in stock.
If you glue the spider down with CA glue you will break everything else before the spider landing glue... but they don't use CA at the build house so the ring was a much simpler solution.
O.G. D-Wet
[]D [] []v[] []D
O.G. D-Wet
Maple Shade, NJ
sundownz
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
