S10 4th order blow through
z0n3d0u7
I'm in the buying / planning stages of a 99s10 single cab blow through build, and wanted some opinions..
My goal, is numbers, moving air, and ability to play music daily.
My plan, is 4 sundown SA12s, in a fourth order blow through (willing to give up the entire bed, less space by the gate for battery's and amps), on a DDm4 @.5ohms. Electrical will be two ad244 145amp alts, a yellow top optima (due to finding one for $50, if you have a better suggestion, I'm all ears), and 2-3 SAMs Duracell g31s with a few runs of 2/0 to the batts, then 1/0 to the amps. Then eventually moving up to better alts, and possibly zv4s at a later date.
Where I'm lost, is what sealed to ported ratio? What tuning? Do I want them in a V shape? Or parallel to eachother?
Could a setup like this be capible of 150+ db?
Any other suggestions?
I'm not TOO concerned with getting real low, but I do want to be able to play around in the low 30s.
I'm not set on a source yet either, but am planning on picking up an audison bit ten D after the holidays. I currently have the 2 sa12d4s, a early (sax?) sundown 50.4 powering some herts high energy 6.5 comps, and an appradio 2 which people are telling me has to go thinking the pre-amps arnt high enough voltage? May do a nexus 7 in the dash
z0n3d0u7
z0n3d0u7
Wichita, KS
z0n3d0u7
