Unless the vehicle has a molex type of connection between the door and the frame, then this wire upgrade will be a large size pain in the a$$ that you do not want to even attempt yourself. If the boot that covers these wires going into the door has a large oval shaped cover at one end, usually the vehicle side, this is a good indication that there is a mnolex hiding in behind it.
If you want to attemp this, you will have to remove the molex and either drill a hole through an area in it where there are missing pins. If there are no missing pins, sometimes you have to reconfigure the pins in both sides of the molex in order to get the factory speaker wires right beside each other (if they are not already). Then remove these speaker wires from both sides of the molex's, drill out the holes and pass your new larger wires through. It is a good idea to run new wires when amplifying front speakers.
