running amp at .5 ohms?
  • 4
cocoleveo7686
MA
Does the amp actually ever see .5? I hear most people saying box rise happens so if wired to .5 ohms ill still be over 1ohms. Is that correct? Im only wondering because I always have run my American Bass Vfl at 1 ohm but if its really only seeing 2 or more than I want to wire lower. Thanks for the help
Pretty much. But box rise is dependent on the enclosure and a few other things. So relying on box rise isn't bullet proof. If you can model your box you can get a general idea of what your box rise will be at at what frequencies. If I were you I would clamp my amp at 2ohm and figure your rise at 2 ohm then go from there.
2x 4 ohm coils can be wired parallel to 2 ohms or series to 8 ohms. There's many amps with 2 ohm power you can use.
383
Is that a car show? Wow. Too much ground loops. The magnetic field may interfere with frequencies going to the antenna. Or you just need a...
15
Thanks for the feedback. It was a long shot but there will definitely be much more powerful subs in the trunk, so clearing it out isn't an option...
cocoleveo7686
cocoleveo7686
MA
noble brown
slater
    May 2, 2024
slater
    May 2, 2024
