Running Active!
I would cross the tweets lower than 2.5khzand keep the mids above 80hz.
twice the FS. read up grasshoppa
Well my sub is is 80hz, so the mid can be 80hz. Thanks man, might do this this weekend //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
or you can have your sub & mids crossed at 100hz.
so set the sub to 100 and mid at 100, i know the sub will stop at 100, and the mid will start from 100 correct?
ill keep the tweet at 2.4k or around that area, cant wait to try this out. thanks james!
They won't stop playing the frequencies, crossovers attentuate the level at which the frequency plays by however many decibels per octave. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
what ramos said. I would also like to add that I like to snowboard down the slopes during the winter season.
-6db/oct = bunny slopes.
Do you know this much when it comes to deadening too? //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
i see what you did there.
uh steep as in a low number or high number, sorry guys :eek:
Think of the description James made with 6db being bunny slopes (shallow), then 24db would be the dead mans drop (steep) //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
you should be.
the number and steepness are positively correlated.
now i understand
i know edead is good deadening //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
//content.invisioncic.com/y282845/emoticons/furious.gif.fc81ca146dbff91fede3ed290dbc4f4c.gif
understood, start at 18 and work my way down, got it!!
Crossovers don't always have to be set identical i.e. high pass on mids at 100hz low pass on subs at 100hz. Sometimes overlap or underlap can be a good thing //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
na_rsx
Incriminator Audio FTW
na_rsx
With Jessica Biel
James Bang
