running active?
For running active you will need a device (headunit, amp, or processor) where you can Actively change and shape the crossovers. For example I use an Alpine 9887 headunit to run my components active.
Hmmm... there sure isn't a FUCKING sticky right at the top of the forum you just posted this thread in...
//content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
nG
people spend more time posting pics of search buttons and complaining. In the amout of time it took to post that B.S you ould just answer his question instead giving him a hard time.
Answer a dumb question and they'll just ask another one.
Baically active is using a seperate amp for each - high, mid, low.
Passive is using a external crossover that you don't have much control over, and the setup would be more of a front, rear, sub.
With active, you will have a different amp for each set up, one for tweets/horns, one for mid drivers, and one or two for subs. and you can actively control which frequencies are sent to each of those amps.
I am running active with one amp //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
You probably meant a separate channel of amplification //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
thegr8cody
thegr8cody
ocean springs,MS
UCF52
michigan born
    May 14, 2026
michigan born
    May 14, 2026
