Running a 3000.1 dc audio amp
Would I need to upgrade my alternator or should I just add more batteries to push a dc audio 3000 watts amp? Im gonna run it at half ohm with my two subs.
What size of alternator do you have right now ? Have you done the big 3 yet ? How many batteries do you have as we speak ?
I hope you realize the power a true 3k amp can produce at .5 ohm...(if you are talking about a true 3k amp) and how much voltage drop you would have. Is your amp even .5 ohm stable? If its not listed in its specs, I wouldn't try it right off the bat.
Its in a 95 accord. It has a 90 amp alternator. Right now I have a audio battery up front and a small kinetix in the back with big 3. Im running at half ohm and my voltage drop to 11. And running it with sky high 0 gauge wire
jh83
jh83
sacramento, ca
mylows10
