running 2nd battery
cant you just ground the amps to the same spot as you grounded the 2nd battery?
You can, but that's just going to add resistance to the circuit.
Same thing with grounding to the frame instead of running straight to the front battery. You are adding 2 extra connections which is has the potential to add resistance to the circuit. A high powered circuit.
krouchchocolate
krouchchocolate
Houston, TX
audiolife
