running 2 amps on 1 sub
ok so it isnt a bad idea? bc i was told it wasnt smart to run 2 amps to onesub...the reason why im asking is cause i can get a 1606d cheaper than if i were to get a 2606d and risk blowing it by running .5 ohm yammean? lol
its ok but you really need to set the gains and all the settings exactly the same.
ok great so it would be at 1 ohm and also i was planning in future to get 1 more 15 re mx nut run them sealed so it will fit in my car..but the question is about that what ohm would i be able run with 2 amps and 2 subs? is it .5 ohm or 2 ohm? or could i run them at 1 ohm?
you simply cannot run a dual 1 ohm sub at 1 ohm with a single amp...its either 2 ohm or 0.5.
yea i was just a little confused with the 2 amps 2 subs deal i dont know why lol...so when i get 2 ill just run them at 2 ohms at 1100 rms per sub... ill be satified with that
thank you all for your help
so actually now that i think of it...it would actually be better to just sell my amp and get a 2608 so then i can run 1700 rms now to one sub then when i get a nother sub i can run 1300 to each
You can also connect both subs in a series/parallel combo to achieve a 1ohm load and then strap both amps to the common 1 ohm load.
I believe those amps have a slave/master so level matching would be easy.
memphis_vette
memphis_vette
Redding, CA
memphis_vette
