Remote Wire!!!!! Help Please
Hey guy's well, I have a stock HU In a car I'm doing an install in, & The whole connect remote to power wire think isn't something they want they don't want it constantly on, However I did recommend a toggle switch to them, But they don't want the hassle,
What do you guy's recommend could I hook the remote straight up to the alternator?
How could I make it to were it only turns on when the car is on or with accessory on?
BTW Is 730 Cranking Amps Good?
Stock Deck, Which means the amp won't turn on due to no remote spot on the back of the deck, You can turn your amp on by touching the remote to the power without any problems, I need to figure out how to turn it on without having the remote wire constantly taking juice from the battery,
the altenator is connected to the battery .. therefore there will be constant power at the B+ terminal of the alternator even when the car is off
you can tap into ANYTHING that turn on when the car is on
Livin' Loud
USA
nathanh
