Running 0 gauge
Pull the seats, pull the carpet and run it where you can put everythting back in without the wire being in the way.
x2. May not even have to pull the carpet completly, I just folded mine. However one day i will be pulling the carpet to do some work to the floor boards, Dynamat, And a carpet kit, So it'll probably get "re-done" then.
I ran mine this way in the grand cherokee. Was doing other work at the same time, so I stripped the whole interior to install new leather/power seats + wiring. Ran it underneath the carpet, under the passenger front seat, then towards the door sills to under the rear seats.
All other installs have been in through the passenger footwell, down the door sills under the molding.
All my bolts were so rusted I couldn't pull the seats out so I had to make do with running the wire under the carpet about 6 inches in. I pulled up the carpet as far as possible and ran it under just past the seat belt bolt in my cavi. It doesnt bulge though which is nice
uGotF-ckedUp
uGotF-ckedUp
platte south dakota
Nut Hair Trick
