Runnin 2 batteries?
  • 2
Do i need like an isolator or someshit like that? Or just positive to positive? Also negative cant I just ground it instead of runnint negative to negative?
Positive from front battery to rear. Ground rear battery.
Sorry my bad Im kinda drunk thats why. Visiting my uncles grave :/ i can ground my amps and battery on the same bolt right? Just need a distribution block right? How many runs do you recommend the battery is for 2000_3500 watts. Im gonna run 2700 wattsrms at most. Also do I need battery isolator or diode crap? Thanks man
139
How have you verified that your alternator is making that much current under real world operating conditions in your vehicle?
That would be close to 4000w rms give or take. I recommend a 75ah or larger AGM battery and a 240a or larger alternator. And you will need 2/0 or...
NADBL is the org that we get up here in the northeast, they do some shows in Ohio and upstate NY and into Canada, might be close-ish to you...
36
4K
BassDrop
BassDrop
SALINAS CA
    May 16, 2024
    May 16, 2024
