run 6x9s and sub on ppi900.4?
C1500martin
Cali
I'm pretty sure i would be able to but i want to double check. Would i be able to run 4 coaxials or 2 and a sub off the ppi 900.4?
its for my girls car just to put a little better music to it the sub is a rockford punch hx2 12 d4
sure.
A d4's not ideal. you'll have to wire it for 8 ohms getting 200w rms vs 300 if you had an SVC4 or D2.
But yeah - a pair (or two pairs) of 4 ohms speakers on 2 ch and the other two bridged to run a sub -- no problem at all.
Actually an efficient way to make use of a 4 ch amp.
sure.
Why cant i wire it to 2ohms? Is it because having 2 channels bridged raises the impedance?
the amplifier is not stable with two channels bridged at 2ohm, however you may get away with it, but not recommended. each channel is seeing 1 ohm
Ahhh ok so im better off getting 2 amps then huh? Becausw right now i have a jl250/1 powering it but i want to give it atleast 400 the sub is barely noticable. Are there any cheap good amps? I dont really want to spend anything on it i want just basic "oh you have a sub and aftermarket soeakers" system.
The lower the ohm load the warmer the amp gets.
Some thoughts.. a Coax speaker may not be a 4ohm speaker. Should check it with a multimeter. If it is like 8 or 6.. You could run them series you could get like a 4 or 3 omh load.
You should try to avoid using an amp channel to support both full range speakers and a sub woofer as a passive crossover (Capacitors) sap power for no audio reward and a stronger chance that the full range speakers will be over driven (blown) due to the desire for louder bass. On a 4 channel amp. I would put the full range coax on two channels. and bridge the remaining 2 channels for the sub woofer. Would be a 1 amp execution.. For me I would do the 4 channel with the 4 coax to give you front to rear fade and get you a separate amp for your sub woof just to keep it nice and clean and cool.
http://www.caraudio.com/forums/amplifier-classifieds/606332-boston-acoustics-gt-42-4-channel-1-ohm-stable.html
I have a boston acoustics gt-42 amp built in italy in mint condition im looking to sell which will handle 2 ohms bridged perfect and is 1 ohm stable per channel. would work perfectly with a dual 4 ohm sub on channels 3 and 4.
WoofersEtc.com - GT-42 - Boston Acoustics 4 Ch. 700 Watt Amplifier
i will ship you mine for 150 shipped //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Just for examples sake regarding electrical, I have 1400 watts total between both my amps and my system has no trouble running everything max...
27
You should run all exact matching subwoofers in one singular enclosure and 1 amp or matching amps for the best listening experience for the space...
I am out of the car audio world the more my ears age. However, I am very much still a hobbyist in the electrical field. With much of my current...
15
Running wattage below RMS won't hurt anything. What the speakers get is the same thing as running an amp with higher wattage and then turning the...
14
C1500martin
C1500martin
Cali
mclerico83
    May 16, 2024
    May 16, 2024
