RPM whine??
check if any of your speaker wires are pinched touching the metal in your car i had the problem and my whine was bad enough it sounded like a weak turbo lol
all trial and error man unhook test hook up test unhook test
rinse and repeat
I had to quote this again, because this is like saying marriage is trial and error... You do it correctly, you only have to do it once. You go at it blindly and you screw up again and again...
alright dude had to be a jackass
you do it your self it works, but you get whine and you dont know why
you dont always get it right the first time you accidently pinch a speaker wire so metal touches metal youll get whine
Ok dude dont be a dick not everyone gets everything right the first time they hook it up there is a shit list of things that could cause engine whine to come from your speakers.
That hardly makes it "trial and error"
That is the difference between doing things right, and just doing things...
//content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
Pinching speaker wire, would be a result of not paying attention to what you are doing. Hence not doing things correctly.
Its a mistake anyone can make, I am not faulting you on that. but doing things incorrectly, and going back and fixing them does not make something trial and error.
You want your answer dumbass, you dont need a filter.
You just need to do all your grounds correctly. thats it. If it sounds too simple to be true, its because it is. You ****ed up somewhere, find where, and fix it. It is that simple.
Or you can waste your money on a ground loop isolator, that will fix your screw up for you. But it is probably going to be easier and cheaper to fix it yourself.
That comment leads me to believe you are a hopeless retard that will never figure out what is wrong.s
Your past few comments lead me to believe a few things.
1. you need to get out of your parents house
2. 6 years on a car audio forum....LOL are you serious?
3. you can't spell, and clearly don't know how to use an "edit" button (after 6 years)
4. Your a complete douche.
Get out of my thread scrub cake:)
you are deff more educated than the OP but you are being a ***. the guy is just looking for some help. and trial and error would be trying one thing then another til its fixed. all the errors are the things u tried but didn't fix the problem. please read a book. this IS TRIAL AND ERROR
Yeah, clearly I'm new at this. And instead of a simple answer he had to be a tool
so even tho his grounds will fix the whine you tell him its a pinched wire? hmmmm NO. yes it could be that but be honest 90% of the time the problem is the ground. but its kool man im sure you're correct.
Iksnipe
Iksnipe
Denmark, Maine
BloodyGuts335i
Mike Mccabe
