BCotrell
All he needs to do is run components that come with drivers, tweeters and crossovers. That can be done with any head unit or amp. I don’t understand what you are getting at. The guy needs crossovers.
how did we come to six drivers, unless you’re talking tweets on front, mids on middle channel and subs on rear.
the filtering is done via a combo of an Amp and the hu. For example, If the head unit has a built in high pass filter for the middle channel you could use its high pass at 80hz, and the amps low pass at . That would give you a bandpass of 70hz to 200hz.
Ur right, I overestimated his hu capabilities. Dsp or passive. I feel shameAll he needs to do is run components that come with drivers, tweeters and crossovers. That can be done with any head unit or amp. I don’t understand what you are getting at. The guy needs crossovers.
