rockville K NINE sub
would i notice a difference between the pine and birch with a single AD XD 12" in a medium sized slot ported box, or not really?
We built 160db cars with with the stuff from homedepot that’s $32 a 4x8 sheet. Sure it might have a few little voids but nothing serious.  Ant bear it for the price and for a single 12” box it will do just fine.
im betting probably not
switch back to your old member name dude, youre confusing LOL!!! and thank you for chiming in!! but srsly, switch back 😛
Cutting mdf leads to lung cancer. Birch is easier and tricky to cut, less sawdust but have a more toothed blade when cutting it to avoid chipping. I just cut some the other day and was so quiet that it was like I wasn't cutting any wood at all. 60 tooth blade works wonders.
The void comment is useless, you wont notice it at all. Its literally just as strong as birch for 1/4 the pricing.  Dont get the 7 layer one, look for any lowes or home depot that carries the 11 layered pine..
11 layered sanded pine is just as good in my opinion. 30 bucks for a 4 x 8 sheet. Same price as MDF, same strength as birch, only a couple lbs heavier.  Makes zero sense paying 120+ bucks in material for a box for a single 12.
that was my thought too. i was figuring that there had to be a cheaper option. Thank you
Definitely! Helps with splintering too.Like a lot of things I had to learn the hard way.
For anyone who might be reading this thinking about trying birch for the first time. Here's the difference between using a 24 tooth blade and an 80 tooth blade. Any guesses witch one's the 80 tooth cut lol
I usually build my own enclosures and didn't have the time to make another box, just happened to have the dual 12" box laying around. I see a 3.5...
387
414
548
youdoofus
Skibidi
youdoofus
planet earth
Boomin_tahoe
    May 24, 2024
    May 23, 2024
