echz
I just picked up the Rockford Punch 800.2 and 2 10" MTX Thunder 6000's. The subs are 4 ohm and do 250 rms/500 peak i believe, and they are wired directly from the amp, so they should be being pushed at 200x2 if I'm thinking correctly. I don't know what's going on with them however, unless they are blown -- They seem to break up and not hit cleanly...They are in a sealed box, in a Ford Probe (hatchback). I'm using a Sony XPlod L-Cube series headunit that does 52x4 and has a separate sub out. I have the crossover on the amp set at ~60, and it's on Low Pass....I've played with the gains and tried everything i can think of, but to no avail. Can someone offer any insight to where my problem may be? Am I overamping these speakers? I don't believe that the system should be sounding as bad as it does...Any help is appreciated! //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
