Rockford power t400.4
d77543020
stockton ca
Rockford t400.4 has some scuff marks works 100 percent RMS Power Output (Watts x Channels) 60 x 4
Peak Power Output (Watts x Channels) N/A
Power at 2 Ohms (Watts x Channels) 100 x 4
Bridged Power (Watts x Channels) 200 x 2
Minimum Impedance Bridged 2
Minimum Impedance Unbridged 1
Best Frequency Response 20-20k Hz
THD at Rated RMS Power 0.1%
Signal to Noise Ratio 85 dB
Input Voltage
1 OHM stable per channel 2ohm stable bridged
180 shipped text 2003903075 for a faster response
668
The surprise wasn’t that they didn’t offer one…it’s how much engineering went into making it easily replaceable, and then not offering one. Maybe...
Thanks ya. Just pulled the trigger on the 1500BDCP because of the constant power that RF developed to help with the ohm rise.
I would pull it and bench test it with a 12v battery. Ive had Bulbs burn out in the past and the amplifier works excellent. They will burn out at...
d77543020
d77543020
stockton ca
d77543020
    May 18, 2024
    May 18, 2024
