12" TC Sounds LMS-R d2
k3n12ock
TC Sounds LMS-R 12" DVC Subwoofer 293-658
Specifications: • Power handling: 1,000 watts RMS/4,000 watts peak • VCdia: 3" • Le: 4.7 mH • Impedance: 2 ohms per coil x 2 • RE: 3.96 ohms • Frequency range: 15 - 150 Hz • Fs: 28.0 Hz • SPL: 84.5 dB • Vas: 1.38 cu. ft. • Qms: 6.70 • Qes: 0.46 • Qts: 0.43 • Xmax: 29.4 • Dimensions: Overall diameter: 12.60", Cutout diameter: 11.16", Depth: 7.15" • Weight: 38.2 lbs.
Dual 2 ohm. In good condition. New in January from Thilo. Only saw about 500rms for about a month or so. No dents on cone. Some scratches on basket. I have the shipping box but not both. Box is big enough to fit both in with a foam on top. I can remove them and ship separately but shipping would go up a bit. I am the 2nd owner.
$300 shipped to your door, or your mama's house.
Trades for an 18" or 2k - 2.5k amp (aq2200 or similar)
USPS
k3n12ock
k3n12ock
MD/CNY
k3n12ock
