Rockford HE2 and MTX 225HO
  • 2
FromKrypton
23
Montreal
I currently have two 12 inch Rockford HE2's being powered by an MTX 225HO. I've wired them into a 1 OHM load. The MTX amp is rated at 400 RMS in 1 OHM. I found that it pounds hard. But I was wondering if I should get a new amp to sqweeze more bass out of my subs? They are after all rated at 400 RMS each sub.
Originally posted by FromKrypton I currently have two 12 inch Rockford HE2's being powered by an MTX 225HO. I've wired them into a 1 OHM load. The MTX amp is rated at 400 RMS in 1 OHM. I found that it pounds hard. But I was wondering if I should get a new amp to sqweeze more bass out of my subs? They are after all rated at 400 RMS each sub.
I've seen bench specs in the 900 watt range on the 225HO, I would think that would be enough power... If you're running the woofers sealed, you'd get a nice output spike from a good ported box..
Loyd L.
You really think my amp is good enough? Specs read that I only put out 400 RMS, and the signed test paper that came with it says it goes up to about 613 RMS. I got my subs in a sealed box. I listen to R&B and Hip hop. Would a ported box really give me that much of an advantage?
Originally posted by FromKrypton You really think my amp is good enough? Specs read that I only put out 400 RMS, and the signed test paper that came with it says it goes up to about 613 RMS. I got my subs in a sealed box. I listen to R&B and Hip hop. Would a ported box really give me that much of an advantage?
I really like that amp... top line in its day. A ported box would slam for rap and such.. much louder than the sealed..
Loyd L.
11
651
The surprise wasn’t that they didn’t offer one…it’s how much engineering went into making it easily replaceable, and then not offering one. Maybe...
9
Thanks ya. Just pulled the trigger on the 1500BDCP because of the constant power that RF developed to help with the ohm rise.
11
990
I would pull it and bench test it with a 12v battery. Ive had Bulbs burn out in the past and the amplifier works excellent. They will burn out at...
FromKrypton
FromKrypton
Montreal
bigbassman
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
