Rockford Fosgate T212d4
  • 1
infamous_e46
hArRy_DaNgLeRs
26,366
California
rockford fosgate t212d4 sub
9/10 its dusty
10/10 mech
280 + ship or best offer
12" Power Stage 2, DVC subwoofer with anodized aluminum parabolic cone, high excursion injection molded thermoplastic rubber surround, 3" excursion, 4" anodized aluminum voice coil former with flat wound aluminum wire, dual 9" mirror imaged symetrical spiders with embedded 12 AWG tinsel leads, dual cast aluminum baskets with spider venting, cast aluminum reversable mounting ring, 304 oz triple stacked motor structure, dual 8 AWG slot load compression terminals, optimized for vented enclosures, 1000 watts RMS/2000 watts peak. Mounting depth 9".
I would pull it and bench test it with a 12v battery. Ive had Bulbs burn out in the past and the amplifier works excellent. They will burn out at...
roger that, just got one from sonic electronix for $189. thanks for the help
18
Maybe ask RF tech support. I wasn’t able to find that either. Sonic electronics and Crutchfield just use the same description as the rf site. True...
After looking at amazon for kicker q product details, it showed rms of 1200@2ohm If you’re at 2ohm you’re not feeding it enough power. At 1ohm...
infamous_e46
hArRy_DaNgLeRs
infamous_e46
California
infamous_e46
