Rockford fosgate t1000bd
lowNlouddd
Banned
246
U.S.A.
Above
Has scratches but works great, missing two screws to hold top plate on, cane be had at Home Depot
220 shipped
USPS
its 1 ohm stable
Yes correct I just checked
but is the 1000 @ 1 or 2 ? (i need 2)lol
It's rated at 1000 @ 1 ohm. But this whole line of amps from Rockford are very under rated. Most bench around ~1300 at 1 ohm. And seeing that it's about ~300 watts under rated and that it's rated at 750 @ 2 ohm. It'll do at or above 1000 @ 2 ohm I'm sure
yup.... thanks.....
The T1000s I've seen had birthsheets of 15-1600 rms. these were very underrated.
Not a lot that high but then again it's not uncommon either. Tony D'amore designed them shits... And he's a amazing engineer. They are amazing amps that's for sure
I would pull it and bench test it with a 12v battery. Ive had Bulbs burn out in the past and the amplifier works excellent. They will burn out at...
roger that, just got one from sonic electronix for $189. thanks for the help
18
Maybe ask RF tech support. I wasn’t able to find that either. Sonic electronics and Crutchfield just use the same description as the rf site. True...
After looking at amazon for kicker q product details, it showed rms of 1200@2ohm If you’re at 2ohm you’re not feeding it enough power. At 1ohm...
lowNlouddd
U.S.A.
lowNlouddd
